Are you sure about that Jugs?Instead of setting the Iginetch to TDC you set it up to 6Deg (or 8 Deg) retarded (when the LED on the pick up plate goes out for #1 cyl) Then in the base advance box in the soft ware put in 6 or 8 as appropriate. This setting is very important. second change the first point of the advance curve #1500RPM to 10 Deg
I think Jugs did mean that the pickup is advanced from TDC by 6to 8 deg Cam, but the word 'retard' is confusing, I think he meant the TDC was retarded ( meaning TDC occurs after the pickup). His wouldn't work otherwise.Are you sure about that Jugs?
If I haven't misunderstood, you're suggesting setting the pickups after TDC.
The base advance in the Ignitech software is exactly what it says - an ADVANCE figure in degrees before TDC. If the ignition pickup plate is retarded after TDC then you need to set a negative base advance to tell the ignition system where the pickup position is. If your pickups are 6° to 8° after TDC and you set the base advance to (positive) 6° or 8° respectively, then your ignition will be 12° to 16° out of calibration and your bike will run like a hairy goat.
I'm not sure about the Version 96 of the TCIP4 software, but all previous versions will not accept a negative base advance, so you can't set the pickups after TDC.
When I install ignitech systems (haven't done a V96 yet) I try to get the pickup triggering as close to TDC as possible without going after TDC. I'm happy with anything between 0° to 3°. I confirm it with a strobe rather than statically with the little LED on the pickup board. Then I set the first advance map point at about 10° at 500 rpm. That way the engine cranks on the starter at base advance, then as soon as it fires up you're on the advance curve. Makes for easier starting and is less likely to kick back and damage the starting system.
Ride to the gate, idle, get off, open the gate, get on the bike , ride thru, idle, get off the bike, close the gate.Ive never ever let my bikes idle cold, ever. Start, choke off, ride. Takes over 30 seconds for the oil to get to the last cam bucket, no way i would let it idle, just ride. Unless you like foulled plugs, washed bores, rooted cams and buckets.... just saying....![]()
Agree Paul, but I've run low on lockdown projects, and no way is cleaning the shed one of them.Seems a lot of complication whereas riding it a couple of minutes before trusting tickover is simple?
Agreed. Setting up the Ignitech is non-intuative but gives you a lot of flexibility ... I'd be interested in the answer to 'advance at idle' comments.This is designed in to specifically help with poor idle timing.
This is all in the instructions but a better help is from the latest version of the "Fast Bike Gear" manual out of NZ available on line. Both need to be read over several times to get your head around the finer points though.
