piranha-bro2
- Melbourne
That's a bummer for you after all that work. I'd also be looking closely at the inlet manifold connection. I'm assuming it has good compression?
Sometimes, unfortunately, the carbs are fit for the bin and cannot be unblocked.Idealy borrow a couple of proven carbs, sometimes those idle passages are bloody hard to clear. I think Paddy mentioned at some time trying 3 or more turns out to see what that does. Big changes are easier to notice or at least they should be. Now who do I know that is great with Dels in Queensland?
^ wot he said.IMHO ultrasonic-ing has little chance if dislodging crap from the idle circuits on these carbs. I recommend you do not place total faith in it.
Sometimes guitar strings are your friends - twizzle twizzle. Study the idle route - as others have said, there are corners
Yes, I've lapped in the intake manifolds and installed new o rings.If you have to add fuel to keep it running then either the carbs aren’t adding fuel properly or there’s air sneaking in later. Sounds like the carbs are spotless now. Checking the intake manifolds was suggested earlier but you haven’t confirmed, apologies if you’ve already eliminated that![]()
Gotcha re the mixture outlet. And I reckon your idea of plug removal is a good one - surely easy to make a plug replacement and fit it. I'm too tied up setting up FCRs to think about it these days.Quentin,
I guess a last resort would be to melt out the lead plug that blocks off the bore to the kink and to replace it after cleaning. Haven't attempted that one yet, may as well give it a go someday.
Hi Bikepirate.
Assuming Idle circuit blockage issues....
Something to try (see caveat)...
Get it started and warm. Choke off. Rev it up and then splat the palm of your hand over the carb intake - leaving the small air entry hole to the idle circuit open if you can. The sudden large draw (low pressure) through the idle circuit can sometimes dislodge a bit of crap and pull it through. The caveat.... Do it at your own risk - all I can say is I have done it dozen's of times with no ill effect, but there is always a first time for mechanical disaster.
I assume you have applied compressed air both forwards AND backwards direction?
Sometimes guitar strings are your friends - twizzle twizzle. Study the idle route - as others have said, there are corners.
Haven't measured the compression as I don't have a suitable instrument but as the engine is fine when on choke can't imagine it would be thisThat's a bummer for you after all that work. I'd also be looking closely at the inlet manifold connection. I'm assuming it has good compression?
Thanks for your input Paul. I fitted new fuel valves and adjusted the floats to the recommended dimension of 24mm but will check them again.It still sounds as if it's not fuelling properly on the idle circuit.
Are you sure the float level is okay?
I may be able to borrow an engine compression tester! What should the compression be?That's a bummer for you after all that work. I'd also be looking closely at the inlet manifold connection. I'm assuming it has good compression?
Float height on the PHF carb is 18mm.Thanks for your input Paul. I fitted new fuel valves and adjusted the floats to the recommended dimension of 24mm but will check them again.
I had some uncleanable carbs,my mum cooked my Dellortos in a pressure cooker using the skillet to keep them off the pan floor- that cleaned them!I've got a couple of bodies seemingly permanently blocked, still a bit reluctant to dispose of them for good. I'll leave them and wait for some magic potion or process to materialise that might give them a chance. I can always have them tossed into my grave if not...
Seems like an excellent idea.I had some uncleanable carbs,my mum cooked my Dellortos in a pressure cooker using the skillet to keep them off the pan floor- that cleaned them!
