breganzane said:
Great to see this thread continuing, and even to get some of the earlier adopters of this into the forum.
Quentin - welcome to the forum, good to hear from you. I assume your SF was the one with ZZR600 front end (or similar) in Victoria back in the early 90's? From my recollections of track days with much the same engine in the old frame it smooths out quite well at high rpm - Cathcart was very impressed with the low level of vibration on the old bike in fact.
Your comments about the twisted twin vibrating more at high rpm is very interesting and informative, as I'd be looking for exactly the opposite characteristic. It does not sound like Phil had the same experience with his - what do you consider 'high' rpm by the way Q&P? I am running the current (tired) engine to 8k and the new one would hope to go somewhat higher.
SteveB
Howy Steve. I'm enjoying my little digital foray back into my workshop
Indeed, my SF1 could possibly have been the one you mention, although there was a guy with a stockish SF with a ZZR front end I met when a journo wanted to feature our modded Lavs in the ill-fated Streetbike - mine has seen numerous guises since I tossed the SF (Super Freni) drum for a used Yamaha TZ 4LS, later replaced by a new TZ 4LS (as an aside, someone on the forum was discussing these brakes, but I discovered they were just a little too light for my extensive road, occasional race, applications; the cast drums would continually warp and eventually separate from the light alloy of the hub outer - super light and fantastic power when it was set up though - there's Super 8 footage hiding somewhere of me outbraking a genuine Imola Rep roundcase SS at the end of Wanneroo's main straight in my very first race
) ... that was a long aside - sorry! My disc front ends went from 35mm Ceriani legs on the original drum brake upper fork assembly, 38mm M1Rs (atrociously set up new from new with no rebound damper piston ring!), Honda VFR 41mm Showas (never set up right, too soft), to current early GSXR750 and 4-spot Tokicos - these went on when I fitted the 17 inch Akronts. Road behaviour has been below par ever since. Final option yet to be fitted, Yamaha FZRR750 USD (Kayabas?), has been in the shed as part of the shelved ongoing project that is my bike these days! Nice pair of 320mm 916 discs and Yamaha monobloc 4-piston calipers to match.
Back to the 270 deg twister. My idea of high revs is around 8,000 - the red I set myself when at a track day or having fun in the real world. But seriously, until I'm convinced my motor is fully sorted in terms of bearing journal wear in the cases and other issues, I won't make any definitive judgement on vibes. I need to see how it behaves with 50% factor when really well put together, then perhaps look at numbers like Phil's 65%. As Tippie says, there are so many other aspects involved in the equation.
i can certainly understand your reticence to alter the sound of the 360 pulse, and absolutely no doubting, a 270 crank sounds absolutely like a v-twin! Just that combined with chain whir, intake throb and the general individuality of a Lav twin's music, it doesn't really sound like a Duke or a TRX (which I rode once, and the motor feels very short in stroke compared to the Lav).
Woops - long post again! And the laptop is about to die of a flat battery!
More soon - keep this thread alive!
Quentin
