Has now mounted the ignition plate and adjusted the points according to the manual.
The problem is that I have to set the rear points to the left cylinder and the front points to the right cylinder to make it all work and not the other way around what the manual says.
Would think the points cam has been mounted 180 degrees incorrectly.
The A-mark is checked against TDC .
Is this setup OK or do I need to fix it.
The engine a 750SF 1973 has been disassembled and assembled by a probably experienced Laverda mechanic
