Pedro
- Nelson, New Zealand
i agree. can i buy new from where??? looks like wolfgang...Maybe it is the picture, but the points cam does not too good????
You sometimes have to twiddle the points gap somewhat to get the timing spot on.Of course iis is correct "dwell" is important for coil saturation, "dwell" is the time the points are open, from one microc mini mm gap to fully open and back to the same dimension. If the max lift gap is correct your dwell should also be correct, but not neccessarrilly, adjusting the dwell with basic points as in the 750 Lav, means varying the points gap, (On old American V8's and Rover V8's after setting the points there is an external screw to adjust dwell on the distributor with the motor running, you need a "dwell meter" it microscopically changes the points gap, but once your points gap is correct, you must time the motor, preferably using a degree disc with a known accurate TDC setting (piston stop is best for this) and first check the fixed points plate side, and secondly check the moving points side, if the first is bang on, then the only way to change the moving side, is move the points set a little and get that bang on as well. My SF1 use to rev its nuts off (stock motor, and later tuned a bit for Egli)) and my SF3 did the same (also stock motor) when I had carried out this procedure.
ps hoping I got that right as points for me are a thing of dinosaurestry, not even my mowers or chainsaws/hedge trimmers have points! (corrections welcomed by iis if appropriate)
Marxy's garage is full of archeology and might only have one of his twenty or so bikes without points!
I think you have it arse-about Clem. Dwell is the time the points are closed. That's when the coil is energised and trying to reach saturation.dwell" is the time the points are open, from one microc mini mm gap to fully open and back to the same dimension.
... I'm with you there 'first principles' and don't over complicate (essentially) a very simple circuitApologies to readers for the original topic/thread, am devoted to first principles as a decisive process in solving difficult faults or designs. Helps others to help themselves, as it may be of use. j.
Ha ha. High praise indeed John, but undeserved. I recently read a book entitled "The Inventions, Researches and Writings of Nicola Tesla". Approx 500 pages of very small print, only some of which I understood. The bloke was certainly a prolific inventor, but he was well beyond my intellectual capability. There were parts of the book where he lost me completely. It wasn't helped by the disappointingly poor reproductions of his diagrams and indistinct black and white photos. Interesting book but no mention of pigeons.Pretty much spot on Cam, your math is commendable, Nicola Tesla would rate you a good engineer, one of my much respected engineer of the era, early days of electrical discoveries ...
Think what could be done with an 'Oil Thread'?Yeah, an in depth discussion emanating from a question about how to set points on an SF. Next time someone asks about adjusting their mixture screws we can get into molecular theory of atomising hydrocarbons. Cool. I wonder if we helped Oehlin get the timing correct.
