I think I picked up one with the devil in it Quentin. Its been a long long road of continuous improvement, just to get it 'tolerable'. It's bloody confusing, all the performance related stuff checks out, but the bike is still a pile of slow, vibratory frustration.
• L & R cylinders hitting TDC together: Yep, bang on.
• Cam timing OK: Yep (and double checked by Sr. Oro after the cam flange separated on the way to Breganze last but one time).
• DMC ignition thrown on - spot on timing and correct advance. Twin outlet coil - nice fat spark.
• Endless experimental jetting changes. Including careful setting of cut away (weaker all-over helped a lot).
• Choke circuit doing it's thing properly.
• Carbs/stubs/isolator/had all smooth bored. No nasty steps.
• Wiring improvements (suspected bad ignition feed - dedicated relay fitted).
• Tappet adjusters improved to ensure true clearances being set (got rid of a bit of dishing).
• Exhaust internals checked for any nasty manufacturing mistakes.
• Compression OK and no unusual hisses when leakdown tests.
The engine always feels like it is fighting itself and just doesn't 'flow'.
When I read your comment about being able to hit twice the 50mph TeddyG is suffering from, I just giggle to myself, mine wouldn't get anywhere near the ton.
This mornings revelation, after the last ride out, suddenly... cannot get first gear. Was perfect when I put it away. No strange noises or change to clutch feel.
Maybe the solution is to give it the 'Full Paul Marx'....
(Sorry Paul - but at the moment if this one burnt, I would do a happy dance around the flames).
Oh, well, I'll wheel it into as corner and spend some time fettling the Jota....
