mikeb
- new zealand
Hi. First post and another ‘strange noise’ question. I’ve just bought a ’74 SF2, fixed a couple of minor things, new oil, adjust tappets, cam chain etc, and had some test runs. It runs ok, ignition still a bit retarded (has a boyer 3). But there a strange noise when under load from about 2000rpm. A kind of metallic loud light-ish clattery thonking. Not a heavy noise. Doesn’t sound like pinking – too harsh/loud. Only when under acceleration and only on-road. When I push the front wheel against a wall and load it up on the clutch I can’t hear it. My first impression is it’s from the head – ie high, forward, tho hard to tell with an alu motor.
Thanks!
Mike
- No such noise when stationary at idle or revs when cold so I doubt its piston slap. The noise is present when hot or cold – and only when the bike is on the road, as above.
- I’ve checked for the 2 cam halves movement, but can’t feel any difference in movement when moving the rear wheel in gear etc. but first laverda so I could be missing something.
- I’ve checked for loose bolts etc and held the tank and various bits while riding – ie in case a harmonic vibration.
- Occasionally its not there, or I can’t reproduce it. But it is 90% of the time.
- I’ve started to wonder if could be rattling in the PFH36 carb slides, but I doubt that would be so loud.
Thanks!
Mike
