some tips, never cut ANY plastic pipe (especially push fit type) with a hacksaw, under a magnifying glass you will see that the ends of the pipe are like circular saws, if you do, and this can damage O rings. ALWAYS use a plastic pipe cutter, its a shear the best is Rothenberger, and then a deburr which gives a tiny lead in, even used fittings can go again if you do this.
Yorkshire (solder ring type) copper pipe fittings are for those who cannot use the (much cheaper) capilliary end feed type, and very often the holding chamber for the solder gets filled with corrosive flux (self cleaning, no steel wool these days) cant be good, and can give problems that the cheaper end feed will not, with no way of flushing the "held" bit of flux out.
Avoid cutting the copper tube with a hacksaw if at all possible (not always the case if cutting a pipe in situ) I have seen many steel radiators with pinholes at the top, caused by copper swarf and self cleaning flux atatching to the top of a rad and rotting a hole. (there is always a bit of air present)
Concrete (in all its forms) will corrode copper pipe, so if this is required wrap the pipe (double overlap) with Denso tape and if its a hot pipe with Denso Therm.You need a god 2" of concrete/mortar/plaster cover or the gease in the tape will bleed through to the surface.
Its a good idea to have a quarter turn (full bore) ball valve at the point of entry of the water main to the house, then if leaving home for more than a day or two, you can quickly shut off this valve. If a freeze occurs, where no storage tank is fitted, damage will be minimal and evident quickly when you turn it back on, if the house does have water storage tanks, the damage will be a bit more severe, but still hugely limited.
Pipe insulation bought in plumbing shops is usually crap and too thin, (the foam type) its a bastard to work with, difficult to get 100% coverage (vital) and even harder to make it stay on, should not even be on sale. dont buy it, go to an insulation supplier and buy, H&V (M&E3) Rockwool, with foil face, (in UK use Sheffield insulations) comes in many thicknesses, use the apropriate thickness, it has a self adhesive flap and you can buy foil tape from the same supplier for the joints and mitres etc, takes a little bit of skill learning but is well worth the effort, remember that your pipe clips will need spacing off to allow for the pipe thickness, in UK these take the form of a clip on spacer for plastic clips, (available in most plumbing shops but rarely asked for, if they blank you at the counter, you are in a crap shop) or you could use brass munsen rings and studding cut to length, together with a female back plate.
Throughly flush all pipes that have been soldered with a self cleaning flux and in the case of closed or semi closed circuits, eg heating, chilled water, secondary hot water, fill and refill several times and use a cleaner if you can be bothered, that is not actually vital as they are all water soluable, an inhibitor is always usefull as are magnetic filters, but you cant beat an old fashioned low loss header for a sump. (an expanded section of pipe, say 3" for a domestic heating system, entry and exit at the top, with a quarter turn valve at the lowest point, helps if that is installed in the lowest point of the system as well, an Ashford blister on the top of it can very often solve problems with systems that are difficult to bleed air from.
I could go on but hey! happing plumbing>
