on these connectors, the locking tang is plastic and is part of the connector body, the plastic tang clicks into a depression in the metal pin itself. So, you have to depress the plastic tang from where the wire goes in, and there is not very much room. I know what the Molex pins look like and their removal tool, those are like a tube that slides up the pin from the other end and depresses the two metal arm that stick out of the Molex metal pins themselves, very different from what I am dealing with.
anyway, the Electronics Supply place had lots of the Molex type pin removers, but nothing along the lines of what I need. I have been poking away with various pointy things including orthodontic wire, will go try a variety of different sized jewelers screwdrivers. This is more complicated because the wires have pulled out of the pins, I have nothing to pull on, need three hands or more to both push and pull and hold, if you know what I mean......
Red very kindly just offered to send me a new upgraded wiring harness, I think I will persevere a bit more with what I am working with here before deciding if I need to take him up on that offer, and to repeat, the problem is of my own ham fisted creation......
Paul LeClair
EDIT - two jewelers screwdrivers worked a treat, jammed one down in from the top to push pack the plastic tang in the connector body, used another from the other end to push the pins out, 30 seconds or less..... THANKS!! My Ignitetch setup is one of the earlier ones supplied with a Sasche pickup board and it came with the connectors and wiring needing to be assembled, and Red had supplied extra pins so I have a couple of extra pins to re crimp and re assemble. I understand from Red he now supplies his own pickup board and a complete fully pre assembled and pre wired wiring harness which would take the ham fisted like me out of the equation in current installs.....
8)
