OneThinBloke
- Oxfordshire, UK
Not long after getting my Atlas I parked up on sloping ground, it was slightly windy. An hour or so later a neighbour knocked on my door: "Is it your bike lying on it's side?"
Pooh.
Await arrival of replacement brake lever. Fit, use bike. Starts fairly easily, as before, but abject to rev much past 5-6k.
Grrrh.
I pondered and pondered. What has changed from before?
Well bike was near vertical, fell sideways and came to an abrupt halt on hitting hard surface.
Ergo: Shit dislodged in the carb.
Contrary to your fears Vince, removing the carb was fairly straight forward. Exploratory dismantlement again quite straight forward. I found shed loads of crap inside the carb. Cleaned using solvent, mechanical and compressed air. Everything replaced as found. 2 maybe 3 hours work, at leisurely pace and basic tools.
Result: Runs noticeably better than before toppling over, except...
Upon finding so much crap in the carb I thought that this could also explain why the bike is glitchy between about 2,700 - 3,000 rpm. However, I also noted the Bosch electronic ignition units being the same as the BTZ 180 triples... Cure not in the carb.
Sensibly priced replacement electronic ignition systems anyone?
Pooh.
Grrrh.
