Thanks Marty. That is period 5 Although methanol isn’t allowed in P5 so maybe it was. It would have been hard to get near the Trex bikes as you said. Period 4 is pre 73.My 3C ran in forgotten era which from memory is period 4. 1973 -1983. I was up against the t rex methanol Honda's. Well, not really in the race. They where a lap ahead of me after 5 laps of Oran Park. Heaps of fun though. I used to dice with a guy on a 650 pantah at the back of the pack.
correct, in BEARs I can modify my bikes as much as I wish to, or as much as Redax can afford to spend on themDrum front and no oil cooler. It's easy to see why Red does Bears, why more interesting Technically.
That’s my thinking too. The rules state you can use tech from the given period, so disk brakes were used before 73, so fine to get log booked. 08 Brembo calibres are accepted too.Some T-Rex Hondas must race P4 because Batto's 917SFC beat 'em and won the championship. You could look into the earliest the factory put a triple on a race track - 1st gen calipers (eg, Grimeca, P Lockheed), 35mm forks and a drum rear might get you in?
Yeah, but they don't like downdraft angles - at all. And having used curved manifolds on Aermacchis for years I try and avoid them where I can.Greg, we’re CR keihins allowed as they are round slides and seem to be hanging off the back of a lot of very fast jap fours in classic racing?
Tom
You'd be very surprised at just how quick a well set-up post-classic can be ridden - even HDs on skinny everythings can produce incredible lap times if corner speeds are high.Skinny forks, skinny tyres, occasional brakes, extra power etc sounds like a recipe for disaster to me. However, also probably highly entertaining, so bring it on…..![]()
In the ninety‘s I raced a Pantah 650 with big fork and brakes. One guy had a 500 with everything smal, fork 35mm brakes 260 and smal Brembo’s. He said: to go fast, you must not brake. When I started braking, he was shifting up.Some people think using a 35mm front end has a weight-saving advantage, and when it flexes like crazy under hard braking they change their mind. Done a couple of front-end changes from skinny to 43mm forks and the difference in feel is incredible under hard braking.
