rocketonarail
- Gloucestershire,England
Back in the early `noughties various suppliers here in the UK sold " state of the art " forged replacement pistons for Laverda triples and twins ....... Miura and Phil Todd sold them .... I got mine from Richard Slater , 80.5 mm , for the 1200 Mirage .
I believe they were made by Aso , in Switzerland , but not Laverda specific as far as I know ............. They were certainly pretty looking things , with a purple ( teflon ? ) coating for the skirts , and a crown finished to a compact disc standard , which you could see your reflection in .......
Not flat top , like the factory fitted 8 : 1`s , but with a slightly raised crown , which would give a CR in the region of 9 : 1 , I would imagine ......
The thing is , the raised crown contained cut outs , for valve clearance ........ one cut out being larger than the other , and I`m certain there was a specific way round these pistons were supposed to be fitted , probably an arrow indicator to point to the front ( exhaust valve side ) ....... It must have been that , although I can`t remember for sure ....
Now , I`m pretty certain about the following , although it was about twenty years ago , and I`m going by memory ......
............ When the pistons were positioned facing in the recommended direction , the smaller cut out was positioned under the larger inlet valve , whilst the larger cut out was positioned under the smaller exhaust valve ............ Logically , you would expect the larger cut out to match the larger valve , and vice versa , but this would mean the pistons would be fitted the wrong way around ( back to front ) , according to the instruction .
In the event , I fitted the pistons the recommended way around , figuring ( hoping ) there would be enough clearance between larger inlet valve and smaller crown cut out ......... The exhaust side of things , with the smaller valve and larger cut out presumably would be ok ..... Also , I was reluctant to fit the pistons the " wrong " way round , in case it would cause problems concerning the weighting , or balance of the pistons ..... probably not , but I don`t really know much about these sort of things .
There was also the thought that the 4C`s lift , and timing , would maybe create different clearance issues , compared with A11`s , or A12`s or whatever , when used in conjunction with these pistons .... but again , that is something I`m not sure about either ......
Didn`t have any problems over the next 15 - 16,000 miles , so that I guess was that , but I wondered if anyone else fitted these pistons at that time , and had any similar thoughts concerning this ........
