Standard battery:
-Elder models: 32 Ah, dimensions 230 x 125 x 165 mm
-SF models starting from 1973: 18 Ah, dimensions 175 x 125 x 165 mm (tighter cams and more revs in slow traffic, etc.)
Note that 18 Ah is also standard size.
All of the capacity is not only for starting a vehicle. Of course in the standard dimensioning of the battery capacity it has also more safety margin for things such more self-discharge in batteries of the era, possibly bigger battery for higher starting current, etc.
The standard 750 generator system don't charge anything at all under 1500 RPM.
In slow city rush hour traffic and similar conditions the battery can be discharging most of the time, or even 100% of time - the battery should be able to storage enough charge in these conditions - lights on. This kind of situation is normal in vehicles equipped with generators + mechanical regulators, the situation is quite different to modern alternators. This is why vehicle batteries often can have lower capacity in systems equipped with alternators.
-Jouni
...in generator systems the charge and decharge cycles are longer than in more modern systems. ...
-Jouni
