Dellortoman
- Tasmania, Australia
You don't have to remove the primary drive sprocket from the left hand end of the crank. If your clutch sprocket is bolted on, just un-bolt it to remove the primary chain. If it's riveted, grind the rivet heads off. In that case, you'll need to tap the rivet holes in the clutch drum to accept bolts. Check out the cush-drive rubbers while you have the sprocket off.
