Dellortoman said:Go to a pet shop and buy a mouse. Train the mouse to retrieve chain link plates (shouldn't take more than a couple of months - mice are quick learners) and send him in through the oil strainer hole. He'll need a little helmet with a lamp on it.
Terry Dymond said:And once again the discussion descends to theinaneinsane. Love it. Keep up the good work![]()
Vince said:All part of the great tapestry of Laverda ownership,sometimes you want to burn them to the ground,till they come good and you go for a nice little ride.
laverdakeith said:If you have dedicated a whole day to getting it out then your simplest and best course of action would be to split the cases and get it out.
Keith
How difficult is splitting the cases?
Grant said:This.
Then again if you are making such a song and dance about finding a link plate maybe you shouldn't try to split the cases.
http://www.amazon.co.uk/Laverda-Triple-Repair-Tune-up-Guide/dp/0979689104/ref=sr_1_1?ie=UTF8&qid=1401367273&sr=8-1&keywords=laverda
Grant said:series 1 we are talking about?
Alternator is out. Starter motor off. Primary cover off. Clutch still in. Green Book open.Grant said:My point is that it's not rocket science and if you are having trouble removing the link then maybe better not start on the cases.
Then again, we all have to learn some time.
How far down is the engine?
You will need to remove the alternator and the inner alternator cover.
Better too to remove the primary drive chain, front primary drive sprocket and clutch.
Just makes re-assembly that much easier.
Removal of alternator (series 1 we are talking about?) needs a special alternator puller (nut on outside is left hand thread plus inner nut is also left hand thread), and the crank nut (right hand thread) on the primary side needs a long reach socket and a crank locking tool. And either an impact wrench or a long lever.
You need to remove the starter motor as there is also an M6 nut under there.
Undo all the M6 nuts first then the larger M8 nuts. Follow the green book.
