cam extractor gt?
Below are the factory tools for the job of extracting the RH cam and the rocker spindles. LH cam is knocked out from the opposite side with a (soft) metal bar. Very early RH cams did not have the provision for a puller attachment, factory manuals show a large screwdriver being used against the side of a cam lobe to bash out the shaft... :rolleyes:
Here it is....
Not a word about being careful or heating. 💩
Thomas aus LAU
Being careful goes without saying (common sense) with any mechanical work, but common sense is not permitted in todays world of safety regulations.
It should also be a simple task to melt the cam out of the head. Aluminium melts at a lower temperature than steel?
