Dellortoman
- Tasmania, Australia
It would be easy enough to make one of those tools. It's just a tube spanner with a screwdriver down the middle of it.
Terry Dymond said:Reckon a socket may provide a bit more 'feel'. Just thought of it and will try it out the next time I fiddle around with the carbs.
Davo said:Carbtune reckons you should be happy if they are all within 2cm. After several (read many) attempts trying to get them exactly equal I gave up and agreed with Carbtune.
motoddrob said:,, an on going one from the inner Alt cover, new gasket too, than I used some 3bond on it and it still leaks!!
& will you blokes get ya farken units calibrated. ???
a cm is not a farken cmHg & is not a farken mill,, or farken mm !!
& 2 cmHg => 0.387 psi. well,, i'm guessing it is close enough.
markQLD said:& will you blokes get ya farken units calibrated. ???
Davo said:From Carbtune ,, the readings should be balanced to within 2 cmHg (some models up to 4 cmHg) of each other."
