Cartridge Kits for M1R
Hi Steve. Really interesting, i never considered Z1000 which would be period correct. Interestingly my xs1100 runs 37mm and has no bushings so they hadn't all gone that way by 77-78.
I run comparable to a 595mm stanchion or 750mm? O/a top to axle centre ( very low for a triple)
I snagged a set of single caliper diversion forks which stand the same height and because the tubes look perfect I'm still tempted to try to get my sliders modified to suit them. Ill get both apart and see if there's enough wall thickness but the breaking point is the company that will machine it or not (not a job for me).
Ill look out for the z option too, maybe they'll work with these yamaha tubes.
many thanks.
Rob, there are several companies in Japan that make new Z1 forks complete with adjustable damping and all modern bushes. Just go on the Webike site and off you go. Typeing in your relevant search criteria will take you down the rabbit hole from which you might not return 😂. There’s some seriously good stuff available for those old clunkers.
Tom
Tom
Thanks tom.
Ive seen it before but its way out of my price range. Thanks to Steve, Ive now ordered my next set of 38mm forks and a new direction.
