Centre stand
fit the stand to the springs and frame first, no bolts, then with a small ratchet cargo strap, arrange the strap so that you can wrap it around the rear wheel with the hooks of the strap attached to the left and right spars pf the stand (so that the hooks cannot slide inward) and then use the strap to pull the stand away and tension the springs enough to get the bolts, the sleeves and nuts/washers in place.
not easy on the floor but we all have bike lifts don't we? easier if you have a folded piece of thin ally so that the strap can slide around the tyre rather than bog in, put the bike in gear or lock the brake. Or any similar variation on the above.
Hey Lowey so as Clem says hang the stand from the springs without putting the bolts in, then move the stand into the bracket, (takes a little force but not that much for a strong Queenslander) then push the bolts through dont forget the bushes and nyloc nuts or loctite.
Easy peasy.
Agree with Maurice.
Best leverage you will get is using the actual stand, just a bit of a bastard when a bush falls out just as you're getting close!
(of course a bit of grease helps....)
Not much space to use the spring puller, unless you hang the bike from the shed roof girders.
Hooking up the spring to frame and stand has proved to be easy, if a little akward and complicated looking at first. Slip the bolts in first, the bushes can be slid in afterwards by wiggling the stand around. Once it has been manhandled into and taken up its basic position it's easy peasy. ;)
Bolts need to be done up tight! I find so many stands with loose bolts... "It won't retract otherwise" is often the answer. It won't retract when tightened 'cos it's fucking bent!! Loose bolts will slowly but surely knacker their holes in the frame, making it impossible to get the stand working properly without major surgery. With the bolts loose, the stand is subjected to various bending forces every time it is deployed.
Just don't use the F&$kn side stand it you can help it ;o)
By the way the spring you are looking for is the same spring used on early SF and SFC BREV drummers also used for the rear Brake light switch and side stand.
Early Breganzies only used ONE Spring for all purposes - Correct me if I'm wrong ;o)
