Hello all, I've been following this thread, as I'm trying to refit my stand, along side the bushman aftermarket sidestand that I've used alongside it since 2016.
I have bike number 6604 / which is a late 1979 orange/silver factory Jota, in the UK.
I've fitted the stand to the bike before, during my time with it since 2015, and I can't recall having the struggle with it, that am now having.
The bike was rebuilt and returned to the road with just the main stand on the bike, last year (only using this again initially). I took the main stand off again, in favour of the after market sidestand kit, last spring. Everything was fine with the main stand last year, as it always has been.
So , forward to now: I'm trying to refit the mainstand, alongside the sidestand kit, again last night (and i've done successfully several times before):
Last night, I tried fitting the stand to the frame lugs and stretching the springs back: but have had no chance of luck there.
Then tried the 'pennies in the springs trick', but I couldn't get enough in the winds to stretch it out (a general problem in life eh!)
Then I removed the the stand at the frame lugs and hung it on the springs and tried to ratchet it toward the lugs. This saw the springs 'pinging' off repeatedly. So I secured the springs on their frame lugs with snug 10mm fuel line clamps and nearly 'got there', until trying to deploy the stand: then the right side spring overcame the 10mm clamp (such was the sideways force at play on the spring at the frame), that spring 'pinged' off again! (left side spring is still in place).
Reaction: "aarrgh, sh!t, b#ll*cks,!" etc. as you'd expect.
I was fighting this bleeding thing from about 7pm to just after midnight last night (I can think of much better ways to spend a Saturday night).
So, it seems that the springs, when hung on stand retainers and the frame spring retainers: don't go straight back in line with each other. Instead they seem to be at about 45degrees to each other, traveling back to the frame, between the frame and stand, is that right? This angle seems to place sideways forces on the spring seat on the frame lug, which then tends to lever the spring off the lug again ... and again ... There's no apparent retainer, to stop the sideways force on the spring, like a clip or something (not that I can see), to hold the circular end of the spring to the frame, I can't understand that; what with forces that they seem to be under.
I still have a selection of both old and new springs that I tried, believe me; I tried them all. Some are obviously stretched and a bit bent, but still there was no joy to be had with those either.
The frame lugs for the springs are straight on the frame and they worked alright just 500miles ago (with nothing having happened to them since).
Clearly I'm doing it wrong now (there's another perennial problem), I can see that, but can't see what it is that am doing wrong?
I looked at the Parker green book; but only found something on stand removal, so no real help to be had there. I've looked across the Internet, and found nothing there.
Has anyone got any photos of the stand and it's springs correctly fitted to the frame please?
As BMW rider too, there are lots of 'how to' videos on YouTube (Chris Harris is pretty great), which are generally great to check your planning of a job, and see what you'll likely need before getting knee deep in a job. I'm wondering if any of members of this brilliant community might consider posting something similar? If the would, I'd gladly watch them
Best wishes to all, I'm off to get some new Bandaids...
