New stanchions have a slightly smaller
inner diameter than the orIginal ones.
So the parts that go in from the bottom
(and the piston-like aluminium part on the far left)
have to be grinded down a bit.
Well that is a bastard and was what I was going to check before ordering the Tarozzi ones. It is far easier to buy from SteinD than from the USA. However my original ones have very small dings in them, which I had thought could have been filled and rechromed, however that would require sending them out of the country, and there is very slight bending in both of them. The Racetech springs jammed inside them at these dings, as there is now obviously very little clearance, I managed to prise out one spring, but the other is really tight and my hook isn't able to get it out, will need some serious persuasion, maybe even destroy the stanchion (edit: I just got it out, a bit more muscle and out it came).
Racetech have stanchions in 570, original SF2/3 length, I contacted them asking about the length of the Ducati 860 ones they list (which he informs me are 605mm). My 595mm ones are what were supplied to me in 1976 from Stanco when I hit a car that turned in front of me in Darwin and I demanded and got a complete front end from the cars insurance, so Keesie sent me one from a triple. My favourite handlebar is clip-ons on top, so the longer ones are perfect for me as they won't require my alloy extensions. The Racetech ones for SF are not in their online catalogue under bike search, SF does not show in the Laverda models at all, so I was very surprised when he gave me the part number.
FTNK 0050557
FORK TUBE CHROME-RSU 38x570mm 32mm ID 33.5x1.25mm Cap Threads
OE# 16790501
Sold Each/per tube: $183.25 each/per tube, for pair order QTY 2. Tubes are in stock at Race Tech.
I think that I will go for the longer ones and have clips on top. I will measure the spring diameter first but hopefully RT springs fit their own stanchions.
Now "all" I have to do is get the ding in the slider fixed, the very top where the seal goes is bent in and cracked so I will see if it can be built up with laser weld or some such and somehow mounted in a lathe and re-machined.
Isn't it fun having a little fall on the road? I am glad it is the bike getting operated on and not me though.
Thanks everyone for your input.
