chrisk
- Brisbane, Australia
Replacing the through bolt with that open ender won’t work for long.
There's no centre or side stand. You'll only be able to park in places where you can lean the bike against something.Anyone spot the obvious engineering issue?
Can you use the heel/ toe mechanism you have on your triple Marty?Right to left conversion would be messy as the available kit is for rearsets
the house of d,artNo centre stand Cam but there is a side stand. How about an engineering solution from Tassie? Can’t take any alloy away from the original lever.
If I machine down the open ender, and drill a hole for the through bolt, what’s stopping it moving sideways, and how do I apply clamping pressure to the spline.
Solution for what? Centre stand or the heel-toe shifter? Either way it's a bit hard to do a custom job without having access to the bike.No centre stand Cam but there is a side stand. How about an engineering solution from Tassie? Can’t take any alloy away from the original lever.
It downloaded and played on my desktop, Marty. Very small blurry vision but could hear what sounded like headers with no mufflers? But I DID hear the first startup! Good stuff!First start but posting a video didn’t work. Bummer.
Think you posted as an attachment instead of a video. Click on the three dots to the right of the usual message edit window to open up extra options. One has the movie camera icon - with the text insert video when you hover over itFirst start but posting a video didn’t work. Bummer.
Yepp - as Q described!It downloaded and played on my desktop, Marty. Very small blurry vision but could hear what sounded like headers with no mufflers? But I DID hear the first startup! Good stuff!
