Grant said:Then yours must be special.
I fit new ones and they are a tight fit.
Might put some grease into it. 100km of oncoming lorries throwing walls of water at you will get water anywhere.
A what??? Speaking from experience there, DM? :-*Dellortoman said:Nightcrawler?Are you sure it wasn't a ribbed condom?
Yes, it can sometimes get wet. And surely you believe everything you see.Paul Marx said:100km of oncoming lorries throwing walls of water at you will get water anywhere.
CLEMTOG said:James WC's problem on the way to Breganze with his eagle was a less than 600 kilometre NEW cable supplied by Venhil,.So jammed was it that he could not ride it any further and I rescued him with a trailer which was carrying TOG (no excuse there as I was also carrying Duff's anni, and he was 79 and intent on riding his Laverda across Piazza Mazzini)
We dropped him off at Andy Wagners and later we were told that there was no internal damage (which we were sure of) and that all that was needed was a replacement clutch cable, it felt as though there was a bit of wood between the lever and the bar, I am not sure what lube (if any) was used in this nylon lined cable, but a conventional one from Wagners (not a Venhill) has solved the problem, still much too heavy, I noticed last week at Baskers that Longshanks has fitted a DAM lever extension.
I hope you don't get the same Paul
I can sell you a hydraulic conversion at what grant would charge plus 100%, with the Euro at what it is that must be a bargain.
