Thanks Piet. Thought so.No. They would only have less pre-tensioning, therefore actually offering lighter action.
Check and lube the actuating lever pivot and pushrod, adjust the screw to optimise lever geometry, eliminate excessive slop. Check and lube handlebar lever pivot and cable, or better still, fit a new cable.
I can supply NOS cables and new repro springs if needed.
I should have put in new springs but I'm careful with my wife's budget even though I put € 1000 of my own hard earned pension money into that bike.If it were me I think I would stick new springs in whilst I was in there anyway.
Just a thought , and I may be wrong , but if the springs are worn , ie shorter than their minimum length limit , then cable free play would need to be adjusted to compensate , meaning that the cable is trying to operate an increasingly (in effect) coil-bound spring , leading to a heavier action , maybe...
Or , to take it to the extreme , imagine how impossible it would be for a (properly adjusted) cable to operate a completely compressed (shorter) spring.
The cable is new Clem. And yes, Venhill cables have a short life expectancy.no ball = no good of course, but from experience a Venhill clutch cable can seize solid, it may be on the way out, when I recovered longshanks from some point in Europe and took his bike (GTL) to Wagners, we all thought a mechanical problem had occured on this newly renovated bike, no-one dreamt it was the bleeding Venhill cable, not even King Kong could have moved the clutch lever, not even a hydraulic clamp would have squeezed it, it was as though there was an invisible block of wood between the lever and handlebar (I think you get the picture), a week later it was fitted with a German totally conventional made cable and was fine, (and still is five years later) the old cable (off the bike of course) was then clearly seized and could not be slid in or out at all.
this happenned in about 700 miles from James house, and started fairly early, got worse, then was 100% duff, he didnt even bother going back to Venhill after my experiences a few weeks early, life is too short.
try to actuate the clutch with the cable off Paul.
It is a Venhill Clem, but new. I have a few standard cables as well including the well lubed one that was on the bike before. If the ball between the rods is missing, the cable becomes a secondary issue.did you not say it was a Venhill Paul?
if so, bin it, and get a totally conventional one made up. Just like the things that were made for about 90 years and then came along "easy slidres or super slickers, nylon lined" etc etc,
the cable on my 1935 Sunbeam are original and work great, but then they should it has only a few years ago passed 20,000 miles from when my uncle bought it new and is now only 100 or so past that.
Hi Paul It can take a bit of mucking around to get that neutral position set up on a 500 (well I found that on my bike).Well, that's a lot better.
Put the proverbial 1/4 inch ball, aka 6.35mm in between the two push rods after having checked the right hand rod for straightness. There was therefore no ball in there. Greased the mechanism, used a NOS cable I had and clutch is a lot lighter. Far from a one finger job however. I hope the Mrs will cope. The setup as it was before meant that either neutral was impossible to find, so agony for the left hand in town, or neutral could be found, but a very heavy clutch action.
We have a rally planned Saturday. I'll test it tomorrow before she gets back from Italy Thursday pm.
The only bodger I trust is myself, I hate all the others.
