TeddyG
- Portland Oregon
The 750 Formula is starting to get some decent bids- too bad it isn't an SF750 that I would otherwise bid on. Do these have some sort of engine issue?
Seller's agent decided to end listing due to the abundance of inaccuracies & will re-list within two weeks.Just had a look at the RGS listing. It says "Auction has expired because there were no bids". Shame that.
A couple of my favourites ..........
" If genius is pain , then I`m in agony ... " .......... ( Charles Dickens ) .......
" Dogs look up to you , cats look down on you ..... but pigs treat you as equals ..... " ........ ( Winston Churchill ) ...........
Not forgetting .......
Lady Astor ....... " If I were your wife Mr Churchill , I would put poison in your whisky .... " .......
Winston Churchill ........ " And if I were your husband madam , I should drink it ....... " .........
" Things are never as good , or as bad , as they first seem ... " ..... ( US Army General Paton ) ...........
So the agent is obviously a covert member of the forum here.Seller's agent decided to end listing due to the abundance of inaccuracies & will re-list within two weeks.
That figures! The revised listing should make interesting reading.The 'covert' agent started this thread!
"Do the best you can until you know better. Then when you know better, do better." Maya Angelou AKA “The Agent”That figures! The revised listing should make interesting reading.
I'm glad it didn't end because of lack of interest. It deserves to be cherished for 'what it is, and what it could be'
Only needs 'that is the question' on the end and we've got another quote...
They can do - that’s a later one so type three crank which is good - the cranks were either good or bad so if it’s a bad one it would have had work or be very rattly - they need regular oil changes - it’s not like a jap bike that you can thrash mercilessly but they are quite quick - will do about 130 mph - 6th is an overdrive really - they have some inherent issues like the stater motor circuit that is not just man enough but you can take steps to alleviate thatThe 750 Formula is starting to get some decent bids- too bad it isn't an SF750 that I would otherwise bid on. Do these have some sort of engine issue?
Some comedy gold on here and no mistake. Could do with it's own thread, this.
Don't think it's my place, maybe one of the 'Elders of the Forum' could knock one up?![]()
I wouldn’t be so sure it has the type 3 crank, and they aren’t much better than the original in terms of the bearing issue. I would be a bit disappointed if only did 130 as I can do that on my 650/668.They can do - that’s a later one so type three crank which is good - the cranks were either good or bad so if it’s a bad one it would have had work or be very rattly - they need regular oil changes - it’s not like a jap bike that you can thrash mercilessly but they are quite quick - will do about 130 mph - 6th is an overdrive really - they have some inherent issues like the stater motor circuit that is not just man enough but you can take steps to alleviate that
All of the cranks in these things let go eventually. There may be a very few that might survive quite decent mileage if pampered, but the machining faults are inherant to all of them. No amount of expensive, fresh oil can cure the fault.I wouldn’t be so sure it has the type 3 crank, and they aren’t much better than the original in terms of the bearing issue. I would be a bit disappointed if only did 130 as I can do that on my 650/668.
Trump talking to Putin in their famous one on one meeting in his first term: “Yes, Daddy.”
Abhi and his crew at Iconic seem to be straight shooters and the real deal......... I haven't purchased anything through Iconic but I have had some very positive interactions with Abhi.I listed a bike -Harley XR1200- on Iconic last July. They assigned a "handler" who did a decent job of vetting me, the pics the bike. Had to answer a list of questions including; length of ownership, known blemishes, mechanical problems & reason for selling.
And earlier this week, I bought one from the "buy-it-now" listings on their site. They handled the back and forth of offer and counteroffer, and took an active role in putting the two of us together and arranging transport, etc.
