Normski said:If the top end isn?t fitted is there any harm in using a rod through the small end eyes to hold the crank on a twin?
Using the big ends to restrain the crank against that type of tightening would not be advisable on any roller bearing bigend motor. Very few people have access to the tool shown that holds the oil pump drive gear, so a rattle gun is the easiest option.Dellortoman said:It would if you put a block of wood under it.
CLEMTOG said:The tool van be easily purchased, (not as original, but very "agricultural") it does work very well, or, if you are in the UK, you could loan one from the club, or maybe a local ILOC member.
