michipons
- Palma de Mallorca
Hi all, and merry Christmas, new year and so on..
I found myself several times looking at my throttle cable/hoses, clutch cables, choke... thinking, now is the time to change them, but forgot to order them, or Wolfang forgot it in the box, or whatsover, then I think it can't be very difficult to do it myself. Cutting cable and hoses is fairly easy, and using solderless nipples is also easy, but most of the times soldering is needed, specially for the handle terminals of the carb terminals, or the 1-2 junction boxes.
There is when it start to get more complex, or at least looks so when looking a bit aroung on the web. I found this article: http://www.vintagebikebuilder.com/building-cables.html
Nipples, cable and hoses are easy to find in Venhill, but apparently the flux used and the torch are also important... I don't know, any of you has made the experience of making his own custom cables?? Any idea where to find the proper flux, torch or nipple stock apart from Venhill?? (Venhill does not provide soldering equipment for those cables)
SRA: https://sra-solder.com/ is a great source, but it is in US, which makes shipping complicated as the flux is not allowed to be transported by air!
So, EU experience would be much appreciated!
Please, refrain yourself to say, "just buy the cable", I know I can do that, but I would like to try my own cables, because then they will have the length I want, at the moment I need them, the threads of the adjusters will not reach the end... and so on
It is frustrating when you have been waiting 2 months for a cable that eventually doesn't fit...
regards,
Miguel
regards,
Miguel
