Dellorto PHB 36
lavgert
Vienna, Austria
Hi, I had the luck to find a Dellorto PHB36 AD housing for my 750 SFC.
Now I am looking to find the left one also: PHB36 AS. I know this will be a bit of a long shoot. Please search your sheds ...
Ciao, Gert
I don't think so Piet. Both are available with accelerator pumps. I think all PHF carbs come with a pump, but it's an option on the PHM. Specifically, its the PHM-B and PHM-N that have the pump.  Perhaps you're thinking of the PHB, which doesn't have any provision for a pump.
As far as I can tell, the only difference between PHF and PHM is the mounting system.
PHF has the solid mount with the clamping ring on the engine side, and a threaded spigot on the air side that you can screw a bell-mouth onto.
PHM has a plain spigot on the engine side that attaches to the cylinder head via a rubber hose type connector. It has a larger spigot on the air side for connection to an air cleaner rubber tube via a worm-drive hose clamp.
Picture below shows the difference.
Picture taken from the Dellorto carby book available here as a PDF https://www.vortex-rok.com/gestione/allegati_news_campionati/88_40.pdf
Clean your specs, Cam. :D
Miguel asked about the difference between PHB and PHF!
No mention of PHM... which are the 38-42mm version of the PHx series.
Are they used on Pan. O forget it. I always had trouble reading that manual. I think some of the translations were a bit wobbly and ambiguous. Took some head scratching to decypher and even then hard to follow.
