Can one drill carbon fibre without it fraying?
I have a pair of painted carbon side panels from Boba for my 3C. Can I just drill them for the tangs of the side panel badges or would it be preferable to just stick the badges on?
burn the holes Paul, just heat a pin of the right diameter to red hot and pierce it through, it leaves a ridge witch for glueing the badge pins on wont matter a jot and leaves the (mini) hole reinforced against future cracking,
I've found that using a bit designed for drilling plexiglas works well on carbon fiber along with fiberglass. The tip is ground to about a 60 deg. angle so it bites a smaller area as you drill through. If you have a scrap bit and a fairly fine grit grinding stone you could grind one yourself.
Just make sure that if you are drilling your new Carbon fairing and you have a nice 80 euro screen behind it the drill does not crack the fucking wanky bastard fucking buggering fucking screen on your last fucking fucking fucking hole!!!!
Just like I did the other day! FFFFFFFFFFFFFFFF
