A couple of us with early triples, one drum and my 3C n° 2098 are having trouble with clutches running dry, there being next to no oil in the primary case.
I think the subject has been mentioned on this forum earlier. These early triples have one hole between primary and main crankcase, that hole being about 40mm above the deck on the primary side. Later triples have larger and more importantly, lower holes between the two compartments.
Is the quantity of oil specified in the crankcase identical in early and later triples? If not, the dipsticks would be different surely. The 750 dipstick on those triples equates with 400cc more oil in the engine when the level is at the top on the stick.
What about the small hole on the oil pumps which squirts oil towards the primary chain on some pumps. Would these pumps be destined for use with the earlier triples?
With the communicating hole 40mm off the deck on the primary side, that would mean 40mm of oil sloshing around in there which seems a lot.
Thoughts?
Thoughts?
