R
Reggie3cl
Guest
Do you know the measurement of yours, Reggie?
Probably shorter than average...
Dale said:I am also starting to get a bit confused about the offset I need.
These discs are marketed with 26mm, 27mm and 28mm offsets, and all claim to fit the same bikes!
Anyone know the correct item?
silvo said:Hi Cam,
All I've heard is that Metalgear discs only work with Metalgear pads. For a master cylinder I'd go looking for one of these. Not cheap but very good combo with O8 Brembos. Steve B. uses one on his bike I think.
Chris
motoddrob said:I called Metalgear, as for the pads, you need to use Metalgear pads only for warranty reasons, otherwise all pads will work. I need to buy new pads anyway so may as well go with their pads first up.
Still waiting to hear back from S3 wether they have disc to suit the early GSXR
Davo said:Oh, and Bevelheaven has Brembo replacement rotors 300mm floaters with 26.5mm offset on 80mm x 6 hole centre carriers at USD $350 ea https://store.bevelheaven.com/brake-related-parts/brake-rotor-750f1-s2-late-900ss-bevel-darmah-etc-300mm-made-by-brembo/
silvo said:Which means that you can buy them somewhere else for half the price he sells them for. Bevelheaven isn't in business to sell to poor Laverda owners. Who's this French rotor mob SF Piet was talking about the other day?
Good to know that you can use any pad with the Metalgear discs.
