TheWrongTrousers
- South London
I guess I already knew the answer to my own question. Thanks anyway guys. Can anyone suggest a place to go who will do a proper job of time certing my studs ? I am in South East London.
Ged at GCS Poole. RecommendedTheWrongTrousers said:I guess I already knew the answer to my own question. Thanks anyway guys. Can anyone suggest a place to go who will do a proper job of time certing my studs ? I am in South East London.
CLEMTOG said:I have bought and fitted new studs as well, because they can lose their ability to clamp, ie linear spring tension.
Dellortoman said:I'm not sure that's a real thing that happens to steel. Sure, the steel properties can change due to temperature, fatigue, etc. But I wouldn't have thought that would be likely of Laverda cylinder head studs. They're not in an extreme environment and they're not torque to yield (single use) studs like a lot of engines have these days, so they're pretty much under-stressed.
What sort of change have you observed in the studs and how could you tell? I'm not saying you're wrong. I just don't know what's going on. Always happy to learn something.
sfcpiet said:piet
CLEMTOG said:CLEM
mcnicol said:One thing to bear in mind with TimeSerts (or similar solid inserts, there's a couple of others around) is that if you have your top crankcase machined out to accept liners for 1200 pistons, the inserts will be VERY close to the big holes in the top case. I'm being very careful inserting the studs in my top case because I don't want this to be an issue.
chrisk said:Re Piets post pertaining to 750 studs.
The Wagner kit that wentboominto mine had to have the studs wasted, as per directions. Surely this wasting would be the weak spot in this case?
CLEMTOG said:750 uses M10 studs, you knew that, and a repair is sometimes made by opening the M9 triple cases thread to M10, and then using 750 studs, turned down to M9 over the length and a new thread at the top, and maybe change the length, or so I have heard, but it would be too much bother for me and I don't think effective, mainly because the stud threads are rolled not cut and accurately taking .5mm off the stud length would be less than easy, without using a cylindrical grinder, which is not by any means a common machine in most workshops. I could be wrong but maybe this is what was meant when the term "wasted" was used.
Clem Clemo, Clemo, Clemo, Clemoooohh
Paul Marx said:Except the 73 SFCs which had 12mm studs.
