The ILOC 50th anniversary book is a great read - lots of info from owners experience - with great picsThanks. I should learn more about Laverda as a marque - any recommended reading?
I'm not sure you can beat iconic orange but I do like the black!Like the black and gold![]()
Plan to come to the New Inn Broadway on the 3rd August for the 50th Jota celebration - should be 250 plus Laverdas there and many people who are part of the Laverda story in UK
Thanks. I'll certainly try and make that.
And I'll order the book.
Jean-louis Olive's 'Legendary Laverda', if you can find an English Language version for reasonable money.Thanks. I should learn more about Laverda as a marque - any recommended reading?
The first book I read was the workshop manual.Thanks. I should learn more about Laverda as a marque - any recommended reading?
They don't go wrong do they???The first book I read was the workshop manual.
A little dry perhaps, but certainly recommended![]()
only if you don't use it !They don't go wrong do they???
Not an orange Jota fan TBH. A Monty, now that’s a different storyI'm not sure you can beat iconic orange but I do like the black!
You could simply try the ones on it now. if the forks end up too short and steep, it's not difficult to make new alu fork caps that extend them enough to allow top fitment of the clipons. But might just be easier to fit original Brevettatos.That's good advice. What bars would you suggest?
'System' as in the concept of clipons above top clamps."later RGS models employed this system."
beware that the RGS series had longer forks than the 180'S. dropping the legs through on a 180 and fitting clip ons above the top yolk would cause the front wheel/mudguard to clash with the exhaust front pipes. unless you stop by only using the rear brake (wincing in horour) but I have a mate who has done that for 40+ years, still scares me.
It's available cheap in French.Jean-louis Olive's 'Legendary Laverda', if you can find an English Language version for reasonable money.
I fell off doing a U turn on my brand new 81 3CL/Jota because of the bars hitting the fairing.If your Jota is a genuine example, it came with Laverda's patent (brevattato) bars. These are clamped under the alloy instrument bracket so sit higher (notwithstanding the fact that they are multi adjustable). No standard Jota came with clip ons below the top yoke.View attachment 97116
