Paul H said:I've worked on 2 750s recently that had double-stacked copper rings. Normal rings, but 2 of them, on top of each other.
Am I missing a trick, or is this just a DPO-error coincidence? I can't see the sense in it, but willing to learn if someone can enlighten.
Original factory exhaust tubes or not?
A bike with a junction tube on the exhaust or not?
The two gasket trick is used when the exhaust roses tend to not clamp down sufficiently.
This will be because of after market exhaust tubes not sealing correctly in the head or the exhaust tube rotating in the head and grinding away at the copper gaskets due to there being no fixed point for the exhaust. The factory "fixed" point is either the under engine junction box or the cross over in front of the engine.
Don't ask me how those very early 750s coped with the exhaust hanging off the clamp into the head and free to vibrate on the rubber mounted rear.
