Rob
- Midlands, UK
There wouldn't have been - since there was no regulator output to drive it, just a rectifier.No Gen light function on mine,
Looks OK - I think (but not absolutely certain) that the ND alternator output cable has some doubled up wiring (like the RGS) but the wires are usually joined and hidden in the sheathing. Maybe someone can confirm, or you can check where the 'spare' yellow and white/blue come from?So with reference to the wires here?s a picture of the area showing the unconnected ones... any thoughts?
CLEMTOG said:aeries 1's had a working red light when fitted with BTZ
series 11's did not have a working red light
Rob said:Looks OK - I think (but not absolutely certain) that the ND alternator output cable has some doubled up wiring (like the RGS) but the wires are usually joined and hidden in the sheathing. Maybe someone can confirm, or you can check where the 'spare' yellow and white/blue come from?
Alternator output is yellow; white/blue; green/white. The yellow and white/blue wires go (via bullet connectors) to the reg/rect. The green/white routes through the headlight switch and returns from there as green/red, connecting via bullet where it changes to red/white on to the reg/rect
So it look as though someone has disconnected the return leg from the headlight switch and connected the alternator direct to the reg/rect. That's OK if you ride with the headlight on, otherwise the reg/rect will be cooked because it isn't rated for the full alternator output. That's why one phase is only switched in when the headlight is on.
As a matter of urgency, you should replace the overheated bullet connector for the red (battery feed) and the white/blue to the reg/rect - they've gone high resistance due to corrosion.
Finally, the reg/rect looks like it may be OE in which case there is nothing to drive the red Gen light. Maurice's suggestion is worth investigating...you'll soon see what's happening after removing the clock cover.
yes I think the reg/rec is original..... Thinking about an electric one.... And Dyna coils.......any thoughts?
Rob said:Guess you mean Electrex. Their RR10 is now a Mosfet device so runs cooler, is more efficient and rated for full alternator output. So yes, a sensible choice given your original item is nearly 40 years old and may fail taking the battery with it.
I personally wouldn't bother with Dyna coils - a lot of money for no useful benefit.
Grant said:That's because it had a CDI ignition.
Only the series 1 180s with BTZ ignition had the appropriate r/r for the Gen light.
It's a good unit which I use myself, but I'd be interested to see how you fitted it to an RGS in the same position as OE. You also need to purchase suitable connectors to do a proper job. In the UK most sellers have twigged that these r/rs are sought after and price accordingly. Easy to end up buying a Chinese knockoff unless you are an anorak too. There is a useful benefit in buying new with a guarantee vs used.It is bigger then the regulator Laverda used but can be made to fit. In my opinion far superior to any of the new replacement units.
No. If you have the Bosch single phase/two charging coil alternator, then the Ignitech R82 will give you a warning light. Similar (but not the same!) size as OE too. It is only suitable for single phase alternators (a la Bosch) not 3 phase (Nippon Denso - series 2 and RGS etc triple variants).So does the Electrex RR10 have an output for for the alternator light??
davidf said:Electrex RR51 has the required wire (white if memory serves correctly). Fitted one to my Mirage and then ran the wire up to the clock - now has a functioning gen light.
HTH
David
