Hi Lothar,
The early version of my 750 was run in an AMA Battle of the Twins class that didn't allow adding a fairing, but seats were free. Often times the back of the bike is more important aerodynamically than the front. A 2" narrower version of that seat, when put on a nearly stock CB125 Honda single (which might have had all of 7 or 8 hp) added an extra 500-800 RPM in top gear with no other changes to the bike.
When I built the MK4 chassis for the racer for the F750 class I added a H-D XR750 long track fairing to it:
http://www.eurospares.com/graphics/Laverda/SF2RRLeftFront1.jpg
Scott says it is looking good to have the racer on the track next year so I'm eagerly awaiting a report on how it goes. I never raced it with the fairing, the newly designed Megacycle cam, JE pistons or the titanium valves.
The Blair papers are all quite good. I look forward to them when they appear in Race Engine Technology magazine though at times they get a bit too heavy in the maths for me. David Vizard also seems to have a good understanding of what is going on in an engine and you can read a series of articles by him on porting that start with this page:
http://www.gofastnews.com/board/technical-articles/980-porting-school-2-super-cheap-flow-bench.html
The people who really seem to know what they are doing often do a test of the complete intake or exhaust system on the head as there's no sense having the best port in the world and then putting on a junk manifold that eliminates 120% of the improvements that you made in the cylinder head.
Here's a scan of a page from David Vizard's "Theory and practice of cylinderhead modification" that shows how a "fat" underhead radius on the intake valve restricts the available flow area in the port at lower lifts.
http://www.eurospares.com/graphics/engine/VizardValveProfile001.jpg
FWIW "swirl", at least in the USA and UK, has a specific meaning for engines. Swirl is a rotary motion about the cylinder axis of the gases in the cylinder. Tumble is a similar motion but around an axis 90 degrees to that. Here's an illustration:
http://tinyurl.com/y95fx4a
Swirl tends to be a concern in two valve heads, while tumble is a characteristic of four valve heads. Jack Williams picked up a bit of power on the AJS 7R by offsetting the intake port a little so as to add some swirl to the mixture in the chamber. It helps promote better combustion.
Scott explained lots of things. An ideal port will be straight and round. Square, D-shaped and oval ports come into play when you try and fit that ideal port into the constraints of a real cylinder head.
You can buy instruments to allow you to measure swirl on the flow bench from places like Audie Technologies.
Scott, you mention using version 3.01 but not which program. Is it Dynomation? You can download the current user manual at
http://www.motionsoftware.com/downloads/Dynomation-UsersManual.pdf
if you want to see what is going on in the newest version of the software.
cheers,
Michael
