Laverda SLO 750
- Slovenija
Hi.
Since my Laverda has been sitting in the garage for the past 15 years at the previous owner, it obviously needs a bit of refreshing in all areas.
I ran into a problem with the front brake. The lower brake lever wasn’t returning to its position when I released the brake lever, but was stopping about 3-5 mm short of where it should be.
So I decided to remove both the front and rear brakes, clean them, and check the thickness of the brake pads. After reassembling, the rear brake works like new, but the front one is like it’s not even there. The brake lever goes all the way in, but the braking power is only maybe 20% of what it used to be.
If I tighten the brake more, the front wheel starts to brake (it won’t turn freely), but the brake lever still goes all the way in without much effect.
I’m attaching photos where you can see that I can almost press the brake lever all the way with one finger, but there’s no significant braking effect.
Cheers, Mitja
Cheers, Mitja
