Front Mudguard for Laverda Montjuic
fintanoc
ireland
would anyone know where to get a new or used montjuic mudguard. I have tried on a number of occasions to contact Boba but no reply.
Forget Boba.
If he replies, he'll take your money and you'll never see the mudguard.
Usual suppliers will supply a 750 SFC guard which is what you want.
thanks for the replies. Laverdian, Could you send me the photos. I have a good mudguard on it but it isn't the correct montjuic one. Whatever about the condition of the paintwork etc I would like the main parts to be match the originals in appearance.
Photos sent a couple of hours ago. Click on the envelope icon at the top of the page, to the right of your username.
Hi. Im no Monty expert but ive seen 2 different styles of mudguard, the jubilee clip mounting and a regular 2 bolt with legs..
Just incase its close, there is this one from Mdina Italia, i bought it because i knew i was going to cut it up to suit a Jota.
Its right for an 18" wheel and certainly too narrow for 38m style forks yokes/ 110 tyre, so may suit some minor mods for a Monty fitting.
Its about 125mm across mounting points but you should check before ordering.
Rob
I could be looking all day and I wouldn't have come across so many options - thanks. For information I measured the mudguard that is on the bike against the 705 SFC laverdian has and it matches well enough on all points except the distance between the bolt points on each side ( 750 SFC = 7.5cm, montjuic = 5.8cm). The width across the lower legs (bolt point to bolt point) is about 14cm on each, the mudguard on the laverda 500 alpino is 10.8cm wide whereas the 750 SFC is 10cm.
I am going to try Wilfried Grahl (Luigi on the forum) before making a move
Not that it’s of much relevance but just for clarity, the pics of the mudguard I sent you Fintan had been fitted to a 750 S (35mm Ceriani forks) and not the SFC.
Copilot says "early" Montjuics used Jota mudguards. "Later" type are clamp on but it doesn't cite a source. This is the one fitted to my W reg bike so I supose the early version [but note I don't know if it's correct or not]20260429_104051.jpg
Try this Yamaha TZ/RD front mudguard. They fit ! Same as the one fitted to the Superbike monoshock special.
Copilot says "early" Montjuics used Jota mudguards. "Later" type are clamp on but it doesn't cite a source. This is the one fitted to my W reg bike so I supose the early version [but note I don't know if it's correct or not]View attachment 104402
This certainly looks like an early front mudguard. Looks like the one on this F500. Always thought they never followed the circumference of the the tyre, like they were meant for a 19" wheel ??
