blab said:So why is it twice the travel on upchange compared to down change ?
The 1mm to 5mm discrepancy at the internal arm has to affect this.
As you have already explained, you have the eccentric at the uppermost position. It should be at the middle position, or very close. THAT would make throws just about even for up and down.
If the pawls do not engage the drum correctly with the eccentric in the middle, or thereabouts, you have either the selector drum fitted incorrectly, wrong selector drum (750 and triple item are mirror-images), wrong selector shaft and pawls, or the pawls have been tampered with. Might be even worse and the gearbox selector forks are worn/bent, selector fork axle locating pin is missing (seen that a few times!), allowing the fork axle to move and droop... all sorts of shit. I really don't expect that sort of stuff though.
With the gearbox in neutral, a pin on the selector drum should be positioned mid-way between the pawls. With the gearbox in gear (any gear will do), the pawls should have a pair of pins, each nestling nicely at each end, roughly equidistant between them.
Disregard the markings on the internal and external selector drums for a start (especially if the origins of these parts is unknown). Get the gearbox in neutral (make sure it is the true neutral! Warning light!) Insert the external drum with a pin at 9 o'clock, or as close as possible, the others leading clockwise from there. This pin should then be positioned in the middle of the pawl leg when the slector shaft and pawl are fitted.
IF all is in good order, there should be no need for bending springs, welding tabs etc. At the most, the tips of the pawls might require a bit of trimming for a smooth lever return to its central position, with the next pair of selector pins engaged ready for the next gear change. The whole adjusting procedure should take no more than 5-10 minutes.
