motoddrob
- S/W Australia
My triple never had a rubber bung. New to me too
I could take it out of the bike to do it, so no probs with any swarf . From memory I think I used my lathe to drill it out.Did yo do that without swarf ending up inside, Chuck? If cases are split it's probably not a bad mod to do anyway - if it means a cheaper easier to obtain part can be fitted it has to be a good thing.
Ditto. I don't need it. I just have had a bolt in there since the ´80s.I haven't had a working neutral light on my SF2 since 1992. I've done 100 000 miles on it. Don't worry, can be done.
Actually (with a Ron system) if the light was on all the time, you'd always be able to start the bike. The switch would provide a permanent earth for the starter relay so it would mimic the normal starter wiring.if I ground the wire it lights the lamp, I forget to change it every time the oil is out, sort of dont care anymore, but if I had done a Ron, then I would never be able to start it!
Must be something wrong with me, I've got a working neutral light on all of my bikes that were equipped with one. Even thought about retro-fitting one to the AMC box of the Matchless.
That's one good reason to have one Rob. I went with an LED idiot light that reads the output from the alternator - different colours and flash frequencies and dims automatically at night. Mainly fitted for the same reason as your neutral light but I get the benefit of knowing what the alternator is doing. Haven't seen it with a running motor yet!!On the Motodd I like having the neutral light, a bright green LED as that tells me the ignition is on as it no longer has the red gennie light since converting to 3 phase Alt. As the ignuition switch is located down by the engine breather I like a warning sign to tell me I haven't turned off the ignition. Did it once at a overnight rally only to have a dead battery next morning.
My SFC being a US spec model is fitted with a neutral light. The Euro models don't have the instruments so did they have a neutral switch fitted to the gearbox or just a plug for the hole. Marnix???
