I don't remember the story that you talk of Alan, was it a road racer?
can you remember or find any of the details,
I wouldn't want the engine unit anyway, far too many mods to make them run on alcohol/dope, I had one of the Toddy engines from Gerry Adams/Chris Atkinson and it had an ex works space frame head (lugs for engine mounts in the sides of the fins) but was trashed by machining down until the exhaust studs were on show, pistons showing welded additions, cylinders equally machined under petrol running comp ratios, totally trashed second and third gears, and the crank, no I wont talk about the crank, but what I must make clear here is that most if not all of the mods I speak of above were done by Chris Atkinson, after Toddy had stopped his involvement, that one was a bit of a bad purchase, and should I be able to find a road race chassis and components I can easily build the motor for it that I desire, would be nice to see my sons give it a go, although it might even be my grandsons if I take twelve years to do it, that will see the two boys at 17 and 16.
