Apparently, ABS is often regarded as a cure-all for stupidity. Sometimes, it even works out that way!
While it may prevent you from falling due to a panic stop in slippery conditions, it may in fact cause you to collide with the obstacle you were intending to avoid. ABS will extract the best possible performance from your brake, but, under certain circumstances this may not be enough. So, a fall or impact might be debatable! While steering is still possible on a 4-wheeler while ABS is engaged, I seriously doubt a severe serve would be possible on a slippery surface with a 2-wheeler with the brakes blocking and releasing in quick sucession. If you don't fall from the tyre letting go when travelling straight ahead, it will let go when side forces come into play. No matter how many electronic helpers come into play, actual physics are hard to overcome.
Far more helpful than a load of electronics is experience and a defensive attitude in traffic, plus a generous helping of common sense.
