Unfortunately I still have one more current case for the “black museum”.
A friend has built a beautiful black (!) SFC replica. The engine used, was from a friend and ran well until it was stored about 10 years ago. He has a big head and has run about 25,000 km.
In the current "revival", the foot- and head gaskets were renewed, as well as the camshaft chain for safety's sake.
The engine sounded good in the first test runs. After approx. 250 km it became very loud mechanically and the valve clearance was checked.
When the engine got louder, the friend came up to me and asked my opinion.
- the very loud mechanical noise came from the top right of the head
- the right outer camshaft ball bearing was ok.
- the camshaft area was well supplied with fresh oil, the surfaces of the cams looked good (mini camera).
- the valve clearance seemed ok
Only after moving the rocker arm from the inlet did I notice, that the play on both sides was about 1.5 mm (!) larger than measured with the feeler gauge.
The valve stems have a very precise „hole“ at the top, almost like being drilled / milled.
I've seen pitting or slight depressions many times, but never before such a crater. Without a lack of oil, I don't (yet) have an explanation.
Why both inlet valves at the same time?
Why did the previous owner not have any problems with the engine?
Hopefully next week when we dismantle the engine we will come across possible causes.
Thomas aus LAU
