Thomas aus LAU
Brutal - how did this happen? Bolt looks ok. What "shoots" from the botom to the top?... one more for the Black Museum!
Ciao, Gert
Thomas aus LAU
Ciao, Gert
I've got an unused pair of them here, if anyone wants to buy 'em! I suspect detonation. Perhaps the lack of a swish band contributes? Running 40 degrees advance on those is pretty extreme, even if CR isn't up to spec.Originally we only wanted to replace a defective (rotating) connecting rod bearing from a friend´s 750 SFC Electronica.
We came across several cracks in both pistons (see red color). I've never seen it like this before.
Does anyone have any idea where this can come from?
View attachment 57199 View attachment 57201
Thomas aus LAU
Yamaha YZF750 do exactly the same - most go un recognised and probably run for ages.
If your small end bush is rotating has the rod end gone oval ? Again oval small ends is a Yamaha problem, gives an off load rattle on overrun , I’ve done a lot of V Max’s with this all caused by over revving. The knocking would also bring on the crack in the gudgeon pin boss in the piston.
Agreed, Clem.it is likely that the elbow fell out before the hose became detached from it, almost definite in fact, is this a £10 Halfords battery? doesn't really matter, but clean the male and female parts for the elbow with spirit and glue it in place with superglue of some sort.
I had better have a look at mine
Yes, Jo, as Clem said, above.Hello Hamish,
is it possible that the breather hose for the battery was secured with a cable tie down there? And that when the hose was caught by the rear wheel and pulled along with it, it then pulled the elbow out from the battery at the top? But only until the elbow got to the cable tie, it finally got stuck there ...
Jo
original pistons? I mean what make?Originally we only wanted to replace a defective (rotating) connecting rod bearing from a friend´s 750 SFC Electronica.
Thomas aus LAU
Original ASSO (no. 2077) in 80.0 for the 1975 Electronica.original pistons? I mean what make?
Just an idle thought ... attaching the hose to the swing arm (which oscillates) may have imparted oscillating forces that were transmitted up the hose to the spigot on the battery, which shook it out.I found it trapped in the cable tie that normally secures the hose to the swing arm.
Before you invest money in the lottery, I recommend that you first invest money in sealants or new sealing rings. The housing looks a bit (too) oily. The way to the rear tire is not far ... Loctite and friends will help you.Question is, should I buy a Lottery ticket?
Thanks, Dellortoman. The hose is loose in the tie allowing it to move freely. The problem was that the orifice, in the battery was a little larger than the elbow, now resolved.Just an idle thought ... attaching the hose to the swing arm (which oscillates) may have imparted oscillating forces that were transmitted up the hose to the spigot on the battery, which shook it out.
Thanks, Thomas. That's, probably, 25,000 miles worth, since I last degreased the back of the engine. It stops the winter road salt whitening the alloy.Before you invest money in the lottery, I recommend that you first invest money in sealants or new sealing rings. The housing looks a bit (too) oily. The way to the rear tire is not far ... Loctite and friends will help you.
Thomas aus LAU
