Dellortoman
- Tasmania, Australia
I don't like snow. Fell on my arse too many times in Antarctica.
Paul H said:Thanks again to all. The generator light has stayed off for 250 miles, so fix looks proper.
I have a new problem. The bike is falling apart underneath me!
Quite a strong knock from motor. Probably left hand side, but not sure. Sound tranfering all over. Slightly Metallic ringing sound to it. Getting slowly but progressively worse. If this bike gets to Breganze, it will be a miracle. I love a challenge....
Paul Marx said:The Swiss are very good with snow.
Italians probably as well.
Tippie said:It?ll very likely be the crank nut. Find a competent person to tighten it as tight as f asap.
AndyW said:Sticking valve? If so it would be as well to identify which one and also to ensure there's plenty of oil being sloshed about up there...
Piranha Brother 2 said:Sounds very much like cam flange area. the key doesn't secure the cam to the flange or timing sprocket, it simply locates it - if the press fit of the cam into the flanges becomes loose the key will do nothing to stop the gradual increase in the movement. It will most likely only affect one side, so take off the tappet covers and observe the rocker movement with manual rotation.
