1200ts
- USA - Riverside CA
Back when I used to work on the older BMW twins (pre 1995 models) you could not raise the compression ratio very much unless you went to dual plug heads or it would knock and eventually a holed piston. The dual plugs allowed you to retard the ignition timing and no more problems.
And Red, with the power you are making, I am surprised the crank cases are not cracking or flexing enough to twist the crank out of alignment. I remember back in the 1970's people racing pro stock Japanese drag bikes (mostly Suzuki GS1000) and the cases were a big problem. At about 175HP they would flex so much it would destroy the crank. Suzuki eventually made a few set of cast iron cases to fix the problem.
