Horn wiring and horn repair
thanks, Piet
will try to finish tracing the black/white wire this evening, it disappears into the main loom as far as I can see, my fancy new multi meter may solve the riddle.......
Paul LeClair
Raul,
The black/white often ends in the multi-pin connector of the switch pig tail, with nothing continuing on from there.  If you can ascertain continuity to ground from the connection inside the switch block, all should be OK... obviously isn't the case.
Don?t forget to read it Paul ;-) it?s all there http://www.laverdaforum.com/forum/index.php/topic,82838.msg173361.html#msg173361
When you check the connection with a multimeter for resistance or voltage you always get a good reading. That?s very misleading but it is because there is allmost no current flowing so there is no voltage drop. It?s as simple as that.
It?s a total different story when the horn current must pass the switch and there is no good (read solid) earth connection. Then you have maybe 6 volts of voltage drop and thus introduces warmth (6v x 5A = 30W) somewhere between the pushbutton, headstock bearings and the chassis so the horns get only 6V, no honk...
grtz,        Ren?
Hi Rene, Piet, and all
bloody hell, I guess I am just stupidly stubborn and need to figure things out for myself, but  Rene is absolutely right, the switch block has the grounding black/white wire going to its output plug connector, and the main wiring harness plug that it connects to is absolutely lacking the corresponding ground wire. There is no bloody ground connection in the factory wiring plug connector.
so, after dis mantling everything, cutting the various looms open, etc., I should have just listened to Rene in the very first place. Interesting factory wiring failure.
I have pulled the black/white ground wire out of its pin block, and will ground it directly to the frame as explained by Rene in his earlier post, and hopefully the horns will honk, then I can take the bike for its mechanical inspection for licencing purposes.
More after I run the new ground wire and put all the wiring and switch gear back together. I am going to look at my two other Laverda triples and see if they share this wiring anomaly even though their horns work somehow.
Paul LeClair
bloody hell, again! I booked my mechanical inspection for tomorrow, THEN hooked all the wiring back up, then tried to honk the horns with the new ground of the black/white wire directly to the frame, and nearly nothing, a tiny little barely audible squeak from the horns...... better than nothing, but not good enough to pass inspection.
so, now I know I am looking for a voltage drop, I have 12.62 volts on the Odyssey PC 680 battery with the bike not running, and I have 11.8 volts at the horns with the ignition turned on, not sure why I am losing almost a volt from the battery to the horns, but I am.
then when I press the horn button, voltage drops at the horns to 7.1 volts and the horns make the tiniest little squeak. These are a pair of brand new pair of horns sourced from Wolfgang that look like the original horns, and do honk loudly when given 12 volts direct from a battery.
I still do NOT understand how the wiring circuit works when both wires the horns carry 12 volt (actually 11.8 volts) any time the ignition is turned on.
so, I probably need to install a relay, but as I don't understand the circuit with BOTH wires carrying power to each horn full time, I have no idea how to wire such a relay. Can anyone explain to me how a relay would be wired into the circuit so that when the horn button is activated that the horns receive the power they obviously need?
I suppose another alternative may be to source a pair of 6 volt horns from an old VW or something........
bloody hell, the horns are keeping me from registering the bike for road use......
Paul LeClair
ps got so frustrated I called Wolfgang, he just laughed and said this is a very very common issue on the triples.
He also told me that there should NOT be power on both wires to the horns, one is supposed to be power, the other a ground connection to be made by the horn button, and that if I am reading power on BOTH wires it must be coming through the horn itself, so I am off to unplug the horns and test the power at the horn wires without the horns. I am also going to go out and pick up a standard four pin 12 volt relay and attempt to wire a circuit. Any help appreciated, I really want to get this bike licenced and ridable to begin the fettling process.
pps Wolfgang told me that Laverda used roughly six different versions of the left handlebar controls switch, which adds to the wiring confusion. Testing the wiring to the horns with the horns dis connected, I have power on the black wire to the horns, and no power on the green/black to the horns. So, the green/black needs to be the ground that activates the horn. With the ignition turned on applying a true ground directly to the green black to the horns makes the horns scream as intended.
so, the defect remains in the grounding. Following all the circuits back, the grounding originates from the push of the horn button on its tiny brass pin making connection through the even tinier spring on the brass pin, to the body of the combined turn signal/horn button framework, which then grounds to the switch housing. Bloody hell, no wonder there is a 5 + volt drop with so much resistance in this ridiculous circuit connection. Normally I wouldn't care, but I have to get the horns working by tomorrow morning.
following Rene's instructions to ground the black/white wire from inside the switch housing directly to the bike's frame reduced the voltage drop but not enough to fire the horns. Grounding the switch housing itself with a second test grounding wire made no difference. So, relay it is going to have to be, wish I understood enough about electrickery to figure out how to wire this circuit through a relay........ but I am going to give it a shot anyway. I need to get a solid switched ground from the horn button to the horn somehow. How do you use a relay to switch a ground becomes the question? Off to Google........
Paul,
Check for resistance in the black/white ground wire, maybe it is perished inside the insulation.  Happens more often than one can imagine!  I had to thread in a new wire for low beam the other day on a triple, there was an interruption right in the middle.  No idea why, it was not in a portion of the loom that was constantly exposed to bending or any other mechanical stress.  I cut open the insulation, the copper strands were very corroded along the entire length.  New wire, all was well.
If you choose to go the relay route, just wire the horns independantly as you would any other component, ie, feed from relay to one horn terminal, second terminal to ground, same for the other horn.  Use the horn button to complete the relay actuation circuit to ground.
If the problem is excessive voltage drop in the wiring (possibly a bad connection somewhere), try hooking up just one horn. You'll reduce the voltage drop and hopefully get a honk out of the one horn that's good enough for the inspector. At least it'll allow you to get it registered. You can sort the wiring properly later.
BTW, a picture is worth a thousand words. So rather than try to explain the horn wiring, it should look like this ... (below)
Simplified Horn wiring Dig from 1000 RGS wiring Schema and simple explanation to go along with it.
Horn and Break lights on Laverda are switched on the earth (return leg) hope it helps
I've reread you post you are correct you have a massive resistance on the earth leg its a good bet it is in the switch or connector block.
Second is Digram with Relay on Earth leg you will need to sort out what is giving you the high resistance later but this should work
thanks, guys!
after I re scheduled my mechanical inspection to Monday, I went and bought a couple of Bosch relays, then hit YouTube..... I am now a YouTube educated "expert" on how to wire relays.
the control side of the relay is terminals 85 and 86 which I will control from the horn button wiring, then fused and ignition switched power in to the relay should be terminal 30, power out to the horns should be terminal 87, with a separate wire from each horn (independent of the relay) to ground.
per Piet's suggestion I tested the black/white wire, major internal resistance with my fancy new multi meter, which resistance is likely at least part of the problem of the significant voltage drop, I am just removing the stock wire and replacing it with new basic black wire (all I have), but I am still going with the relay for the horn circuit after all this futzing around. This has been a good learning experience for me, even if it seems really simple to some of you.......
thanks for all the help, hopefully the relay is the solution to get the horns working properly.
Paul LeClair
No need to run separate 12V supplies for control and power wiring. Just run your fused power supply to terminal 30 and put a little bridge wire between terminals 30 and 85.
If using a relay, take a wire that?s thick enough to let pass the horn current (between pins 30 and 87 from the relay). Compare it with the existing wiring from to the horns, or better a bit more in diameter. Otherwise again you will have a voltage drop over the wire.
With the relay your existing wiring is then only feeding the coil from the relay, pin 85 and 86 and is not critical for wire thickness because the coil of small relays takes mostly not more than 200mA. No problem for the pushbutton wiring and there will be / must be a good HONK :-)
grtz and suc6 with the registering of the bike,    Ren?
Paul LeClair said:
thanks, guys!
Paul LeClair
Paul your description sounds like you are going to put a relay on the power side of the horn . Valid option. Trap for young players is that on some models power for break lights power loop of the horn supply so make sure you put relay in after that point if you set relay on power side. The diagram I sent you was for relay on earth side. So the original horn fuse will cover the power and no change to break power supply
Good luck
Jugs
success, and then some...... 8) I solved my voltage drop issue to the horns on my 82 1200 TS Mirage project build, with lots of help from all of you, thanks!
finished the re wiring, with relay, all new wires, inline fuse on the power source to the relay, power feed only switched off the relay direct to each horn, and each horn individually grounded full time. So , no power to the horns unless the ignition is turned on and the horn button is depressed, triggering the relay switch. Used all heavier wire than stock.
first test honk in the garage startled me, woke up the half deaf geriatric Golden Retriever sleeping at the other end of the house who jumped up startled and barking, and caused my spouse to come running out into the garage to see what the heck was going on. Bloody loud, using just stock horns it is WAY louder than a car horn.
Amazing what a full 12 volts + to the horns results in by way of sound volume. I am going to do the relay install in the same manner on the other two Laverda triples in the garage.
so, in the end, here is what I wound up doing.
I took the left handlebar switch cluster apart, took the dinky little horn button out, took a file to the end of it to clean it up, stuck a small file inside the turn signal housing where the horn button end makes contact, and cleaned that up nice and shiny.
then I traced the black/white ground wire out of the switch cluster to find, as Rene predicted, that the ground wire out of the switch cluster to its main white connector does not have a matching ground wire on the other side of the white connector. On Ren?'s advice, I fished the black/white wire out of  the white pin connector, and made a direct ground wire connection to the bike's frame. Better, got a tiny little squeal/beep at the horns and 7.2 volts, but not nearly good enough.
then I went and bought a relay, wound up with a Bosch 5 pin relay (only need 4 pins) at the local Auto Value for the rip off price of nearly $17. Later I went to my electronics wholesaler where I usually buy my stuff, and bought 6 extra Tyco Electronics 5 pins relays, seemingly identical to the Bosch, for $3.85 each, bloody hell.
with my new found YouTube sourced knowledge that pins 85 and 86 are the control switch side, I traced where the Laverda main wiring harness has the two wires out to the sub loom to the horns, unplugged the small horn loom and removed and discarded the stock four wire horn sub loom, not to be re used. The stock horn sub loom has two power wires (one for each horn) and two ground wires (one for each horn), and the stock wiring has power full time to the horns when the ignition is switched on. The horn honking with the stock wiring happens  when the horn button is pressed, going to ground through a tiny little pin and tiny little spring, completing the circuit. Anyway, I figured out which of the main wiring loom output wires to the horn was power and which was ground, which turned out not to matter to wiring the relay anyway. I then made new wires to connect the two horn button outputs from the main wiring loom (just plugging onto the stock connectors,) and used the new wires to connect to each of pin 85 and pin 86 on the relay. I mounted the relay under the seat on the rear fender simply because that allowed me to use just a short large power feed to the relay from the battery as well as use an existing hole in the fender for mounting. I  did not want to drill any new holes, otherwise I could have put the relay just about anywhere I could have hidden it. To test proof of concept, I turned the ignition on and pushed the horn button, the relay worked and I could hear the little contact switch inside the relay click.
from there it was just a function of  running a heavy power feed cable (with inline fuse) from the battery positive terminal to terminal 30 (power in) of the relay, then running a single power feed wire forward from pin 87 on the relay to the same location on the wiring loom just above the carbs where the control wires for the horn are also located, just to make everything neat and logical. For my wiring circuit pin 87a is not used on this 5 pin relay and is not needed, if I could have found a four pin relay to buy I would have.
then I made a brand new sub loom for the horns, (power wires only, no ground wires) tied two heavy duty power wires together into one connector to plug into my power feed wire above the carbs from the relay, and ran one heavy gage power wire to each horn. Then all I needed was a ground for each horn, so I made short ground wires, plugged into the horn terminal with a short run directly to the bike frame. All looks very neat and tidy, I used professional connectors, every connection is shrink wrapped, etc. The horn power is ignition switched, as the horn button wiring that triggers the relay does not work unless the ignition is on.
a lot of time for me and my electrickery challenged brain, and a couple of hours fabrication believe it or not, the guys that are good at this stuff are welcome to laugh at me, but I did eventually get a great result. Oh, and for the commenter that warned me about the brake light circuit, I did check and the brake light works fine, thanks for the warning! My hat is again off to you folks that do this stuff for a living, for the less experienced of us there is always something to learn, now I clearly understand how a relay works and how to wire a relay for various purposes. The relay control side, pins 85 and 86, don't care if they are controlled/switched by power or ground, and there are at least a couple of other ways to wire the horn circuit I described, in my electrickery ignorance I just did not like the idea of having full time power running into the horns (with the ignition on) as the stock wiring does, so at the horns I used constant ground and switched power.
I am also thinking this voltage drop issue caused by the horn button, grounding issues, and deteriorating wiring and grounds, must affect a lot of the existing Laverda triples, I wonder how many horns out there actually work properly or at all......?? I got driven into addressing this issue because my bike has to pass a mechanical safety inspection so I can register it, I don't think I would have spent the time and energy otherwise on this issue, frankly.
thanks for all the help, everyone, sincerely appreciated!
Paul LeClair
ps the inline fuse receptacle does have a sealing top cap and will be water tight once I go out and buy the correct sized fuse, the fuse I am using at the moment is too large to allow the top cap to snap into place - one more run to the Auto Parts store required....... ::) ::) ::)
In itself it would have likely overcome the issues you found.
I had 7 volts at the horns even after cleaning all the contacts and making proper earths.
Fitted a relay in the same way you did and it cured the problem.
Paul, as I recall 87a is hot when 87 is not, so you have a live spade on the relay all the time, except when you use the horn, so you may want to cover it with a spare female connector just in case something accidently comes in contact with it.
Stu
Stu
Hi Stu
yes, 87a is hot even when the ignition is off, which is why I would have preferred a 4 pin relay, but I could not find any in stock. Good idea to cover it, I will do that. The only time 87a is not hot is when the relay is triggered, so in this wiring circuit, 87a would only be without power when the horn button is actually pushed. I suspect you could use 87a for all kinds of interesting things in other circuit types, maybe hook an indicator light to it, etc.
Has your Slater's 1200 Formula turned a wheel yet this year? Keep in mind this year is the very last rally at Wolfgang's, you should dig the Formula out and bring it along!
Paul LeClair
