Andy J
- Isle of Man
Was working on one of the 500 twins today with the intention of getting it ready to ride at the weekend. When I bought it, it came with some very old tyres fitted, so I just rode the bike accordingly and didn’t lean it over too much and whack the throttle open wide. My 350 is currently awaiting some attention, so I decided, as it has some relatively young tyres, to do a wheel swap. Having removed the 350 wheels I then traveled with them to my other lock-up to do the switch.
First problem was undoing the wheel nuts. I’ve no idea who the last person was that did them up, but I’m surprised the bearings didn’t squash. The wheel spindles also took a bit of persuading to pull out, but when I went to refit the rear wheel I couldn’t get the spindle back all the way through and initially couldn’t understand why, everything seemed to be lined up correctly. After a bit of experimentation I then discovered one of the holes on one of the chain adjusters wasn’t sufficiently round and was binding on the spindle. A few strokes of a file solved that issue.
I then moved onto the front wheel. I drove the wheel spindle out and expected the front wheel to just drop down. It didn’t, it just remained in place. I was rather baffled by this. Thinking the brake pads may have just stuck to the discs I gave the wheel a bit of a yank but it wasn’t playing. So why not remove the callipers. Because a previous owner had replaced the Caliper bolts with some shiny but soft cap heads that are so tight they won’t budge and the heads are going to get rounded off if not removed carefully. So knock out the pads and it still won’t drop out. On closer inspection I observe the outside of the disc, on both sides, is hard up against the side of the slot in the caliper. How the hell anyone fitted them like that is difficult to fathom. Assuming it’s possibly an issue with the discs I try fitting the other wheel, but it’s exactly the same, so it’s a problem with the forks or callipers, as the wheel that came out the 500 fitted straight into the 350 forks and callipers.
Therefore, it doesn’t look like I will be riding it this weekend.
