Robin Webster
- Silverstone
Hi, on the 12th July my 3C popped, backfired and stopped. I’ve not had it running since.
I have replaced the battery, the plugs, an Electrix World RR and now fitted a new Ignitech box and their single and double coils ( single to pot 2, double to 1 & 3). They have a connector block that fits the OE wiring block. It does away with the red power wire which I used to connect to their supplied red power cable to the ignition unit. No spark.
I then connected their supplied red cable to the battery via a 15amp fuse and plugged that in which gave me strong spark at the plug but the bike would not start and backfired. I have tried swopping the orange/red coil supply wires with the white/red wires from the other coil but that did not work, so now it is orange/red to coil 2 and white/red to coil 1&3.
The only thing I can think now is timing but it was running on the 12th July.
Getting fed up.
Robin
Getting fed up.
Robin
