breganzane said:Every digital ignition has effectively the same feature - but with IIS and Sachse (not sure about DMC) it is done to TDC rather than base advance and thus can be done statically.
Steve,
The DMC system incorporates a "wandering" advance feature to maintain a steady idle. It does not have a fixed advance at idle speed, the markings may jump around quite a bit at idle speed when strobing. It is however dependant on hardware positioning and can therefore be operator influenced to a certain degree. This is why the system should be set at a checked/verified factory specified full advance mark for the particular model the system is being fitted to. The system of course uses the "normal" inducer/trigger relationship as a base line from which the curves are calculated, but for all means and intentions, using full advance as a reference for adjusting is a lot easier, and safer/more reliable. Curve #1 in all DMCs is an equivalent to the stock ignition setting. Once this is checked and adjusted,the individual curve programms go from there.
Due to a programming glitsch, a few DMCs will not readily allow the engine return to idle speed, instead the revs hover a bit higher, only to drop rather suddenly and the engine dies. In this case, advance at idle is insufficient. No amount of carb fiddling will cure this condition, ever! A simple fix is to dial a curve with less full advance, ie, 28? instead of 32?, and adjust this to the standard markings. In this case, an additional 4? of advance will be available and idle will become rock-steady. Advance at idle (800-900rpm) should be based at around 5-8? BTDC but is relatively immaterial, full advance of course is dependant on engine specifications and is extremely important.
Hope that makes sense,
